    40 Posts 2 Posters 28.3k Views 1 Watching
    • H Offline
      hello @hello
      @hello
      • H Offline
        hello @hello
        @hello
        进行4.2.1视频预览测试没有出现预览:
        • H Offline
          hello @hello
          @hello
            veye_xumm @hello
            现在你的系统检测到了。
            • H Offline
              hello @veye_xumm
              • H Offline
                hello @hello
                @hello
                New clock: GstSystemClock
                Setting pipeline to READY ...
                Setting pipeline to NULL ...
                Freeing pipeline ...
                root@hello:/dev# dmesg
                [ 4.451868] CPU1: shutdown
                [ 4.509501] CPU2: shutdown
                [ 192.439657] Enabling wake24
                [ 192.445718] Enabling wake53
                [ 192.474213] Enabling wake83
                [ 192.474222] Enabling wake29
                [ 192.486471] Enabling wake76
                [ 192.486473] Enabling wake77
                [ 192.486475] Enabling wake78
                [ 192.486477] Enabling wake79
                [ 192.486479] Enabling wake80
                [ 192.486481] Enabling wake81
                [ 192.486483] Enabling wake82
                [ 192.486520] Enabling wake73
                [ 192.555437] Enabling wake71
                [ 192.587463] CPU3: shutdown
                [ 192.619451] CPU4: shutdown
                [ 192.647445] CPU5: shutdown
                [ 192.652403] Entered SC7
                [ 192.652403] Exited SC7
                [ 192.658275] CPU3 is up
                [ 192.664019] CPU4 is up
                [ 192.669812] CPU5 is up
                capture channel
                root@hello:/dev#
                • H Offline
                  hello @hello
                  @hello
                  关于这个提供下下载的链接吧?
                  下载来源如下:
                  这个不是最新的吗?
                  另外使用新的dtb做法是直接拷贝覆盖吧?可要烧写步骤呀?
                  • H Offline
                    hello @hello
                    @hello
                    下载如下的dtb
                    烧写更新完成后发现摄像头sensor都检测不到了???
                      veye_xumm @hello
                      @hello
                      dmesg | grep veye
                      1. 请检测一下你的排线有没有插歪了的情况?
                      • H Offline
                        hello @veye_xumm
                          veye_xumm @hello
                            veye_xumm @hello
                            @hello 请问解决了吗?
                            • H Offline
                              hello @veye_xumm
                              @hello 请问解决了吗?
                              谢谢
                                veye_xumm @hello
                                • H Offline
                                  hello @veye_xumm
                                  刚试了很多次,不行,没效果
                                    veye_xumm @hello
                                    @hello
                                    你在终端杀掉gst-launch-1.0进程也是可以的
                                    • H Offline
                                      hello @veye_xumm
                                      @hello
                                      现在全屏都是预览的摄像头画面,退不出来,进不了终端
                                        veye_xumm @hello
                                        • H Offline
                                          hello @veye_xumm
                                          好的,感谢,需要的就是这个
                                          • H Offline
                                            hello @hello
                                            @hello
                                            已经通过建议方案2成功退出预览,问题解决,谢谢!
