    55 Posts 3 Posters 41.2k Views 2 Watching
      veye_xumm @Otca
      @otca
      • O Offline
        Otca @veye_xumm
          veye_xumm @Otca
          @otca
          • O Offline
            Otca @veye_xumm
            • O Offline
              Otca @Otca
              Do u know this issue?
              • O Offline
                Otca @Otca
                  veye_xumm @Otca
                  • O Offline
                    Otca @veye_xumm
                    i2cdetect -y -r 9
                    70: -- -- -- -- -- -- -- --
                    i2cdetect -y -r 10
                    ls /sys/bus/i2c/drivers/
                    extLinux Config
                    LABEL imx264
                       LINUX /boot/Image
                       INITRD /boot/initrd
                    Upgarde Jetson Jetpack 6
                    sudo depmod
                    tegra-camera.ko
                      veye_xumm @Otca
                      @otca
                      veye_xummV O 2 Replies Last reply Reply Quote 0
                        veye_xumm @veye_xumm
                        @Otca
                        • O Offline
                          Otca @veye_xumm
                          thanks for your guidance.
                          The dmesg log is appended.
                          MV-MIPI-IMX264.txt
                            veye_xumm @Otca
                            • O Offline
                              Otca @veye_xumm
                              Thanks alot
                                veye_xumm @Otca
                                @otca
                                • O Offline
                                  Otca @veye_xumm
                                  here is dmesg log.
                                  sudo dmesg| grep -i 'mvcam'
                                  Full DMESG Log:
                                  IMX264.OrinNX.txt
                                  i2cdetect -y -r 10
                                  VLC:
                                  vlc
                                  Opening in BLOCKING MODE
                                  DTB :
                                  TIMEOUT 30
                                  DEFAULT imx264
                                  MENU TITLE L4T boot options
                                  LABEL primary
                                        MENU LABEL primary kernel
                                        LINUX /boot/Image
                                        INITRD /boot/initrd
                                  LABEL imx264
                                        LINUX /boot/Image
                                        INITRD /boot/initrd
                                  O veye_xummV 2 Replies Last reply Reply Quote 0
                                  • O Offline
                                    Otca @Otca
                                    • O Offline
                                      Otca @Otca
                                      Dmesg Logs
                                      Dmesg_01.txt
                                      v4l2-ctl --list-formats-ext
                                      ioctl: VIDIOC_ENUM_FMT
                                      	Type: Video Capture
                                      	[0]: 'GREY' (8-bit Greyscale)
                                      		Size: Discrete 1920x1080
                                        veye_xumm @Otca
                                        @otca
                                        export WIDTH=2432
                                        export HEIGHT=2056
                                        export FPS=28
                                        v4l2-ctl --set-ctrl roi_x=0
                                        v4l2-ctl --set-ctrl roi_y=0
                                        • O Offline
                                          Otca @veye_xumm
                                          @veye_xumm Hi,
                                          this is the results:
                                          export WIDTH=2432
                                          export HEIGHT=2056
                                          export FPS=28
                                          Dmesg log:
                                          ####Dmesg of Last Line:
                                          Full Dmesg log:
                                          Dmesg.txt
                                            veye_xumm @Otca
