    55 Posts 3 Posters 42.8k Views 2 Watching
    • O Offline
      Otca @Otca
        veye_xumm @Otca
        • O Offline
          Otca @veye_xumm
          i2cdetect -y -r 9
          70: -- -- -- -- -- -- -- --
          i2cdetect -y -r 10
          ls /sys/bus/i2c/drivers/
          extLinux Config
          LABEL imx264
             LINUX /boot/Image
             INITRD /boot/initrd
          Upgarde Jetson Jetpack 6
          sudo depmod
          tegra-camera.ko
            veye_xumm @Otca
            @otca
            veye_xummV O 2 Replies Last reply Reply Quote 0
              veye_xumm @veye_xumm
              @Otca
              • O Offline
                Otca @veye_xumm
                thanks for your guidance.
                The dmesg log is appended.
                MV-MIPI-IMX264.txt
                  veye_xumm @Otca
                  • O Offline
                    Otca @veye_xumm
                    Thanks alot
                      veye_xumm @Otca
                      @otca
                      • O Offline
                        Otca @veye_xumm
                        here is dmesg log.
                        sudo dmesg| grep -i 'mvcam'
                        Full DMESG Log:
                        IMX264.OrinNX.txt
                        i2cdetect -y -r 10
                        VLC:
                        vlc
                        Opening in BLOCKING MODE
                        DTB :
                        TIMEOUT 30
                        DEFAULT imx264
                        MENU TITLE L4T boot options
                        LABEL primary
                              MENU LABEL primary kernel
                              LINUX /boot/Image
                              INITRD /boot/initrd
                        LABEL imx264
                              LINUX /boot/Image
                              INITRD /boot/initrd
                        O veye_xummV 2 Replies Last reply Reply Quote 0
                        • O Offline
                          Otca @Otca
                          • O Offline
                            Otca @Otca
                            Dmesg Logs
                            Dmesg_01.txt
                            v4l2-ctl --list-formats-ext
                            ioctl: VIDIOC_ENUM_FMT
                            	Type: Video Capture
                            	[0]: 'GREY' (8-bit Greyscale)
                            		Size: Discrete 1920x1080
                              veye_xumm @Otca
                              @otca
                              export WIDTH=2432
                              export HEIGHT=2056
                              export FPS=28
                              v4l2-ctl --set-ctrl roi_x=0
                              v4l2-ctl --set-ctrl roi_y=0
                              • O Offline
                                Otca @veye_xumm
                                @veye_xumm Hi,
                                this is the results:
                                export WIDTH=2432
                                export HEIGHT=2056
                                export FPS=28
                                Dmesg log:
                                ####Dmesg of Last Line:
                                Full Dmesg log:
                                Dmesg.txt
                                  veye_xumm @Otca
                                  • O Offline
                                    Otca @veye_xumm
                                    sure!
                                      veye_xumm @Otca
                                      @otca
                                      • O Offline
                                        Otca @veye_xumm
                                        r trigger mode is 0
                                        • O Offline
                                          Otca @Otca
                                            veye_xumm @Otca
                                            @otca You are welcome.
                                            This issue is a bit strange.
