    55 Posts 3 Posters 39.9k Views 2 Watching
      veye_xumm @Otca
      @otca
      • O Offline
        Otca @veye_xumm
        • O Offline
          Otca @Otca
            veye_xumm @Otca
            @otca
            • O Offline
              Otca @veye_xumm
                veye_xumm @Otca
                @otca
                • O Offline
                  Otca @veye_xumm
                  • O Offline
                    Otca @Otca
                    Do u know this issue?
                    • O Offline
                      Otca @Otca
                        veye_xumm @Otca
                        • O Offline
                          Otca @veye_xumm
                          i2cdetect -y -r 9
                          70: -- -- -- -- -- -- -- --
                          i2cdetect -y -r 10
                          ls /sys/bus/i2c/drivers/
                          extLinux Config
                          LABEL imx264
                             LINUX /boot/Image
                             INITRD /boot/initrd
                          Upgarde Jetson Jetpack 6
                          sudo depmod
                          tegra-camera.ko
                            veye_xumm @Otca
                            @otca
                            veye_xummV O 2 Replies Last reply Reply Quote 0
                              veye_xumm @veye_xumm
                              @Otca
                              • O Offline
                                Otca @veye_xumm
                                thanks for your guidance.
                                The dmesg log is appended.
                                MV-MIPI-IMX264.txt
                                  veye_xumm @Otca
                                  • O Offline
                                    Otca @veye_xumm
                                    Thanks alot
                                      veye_xumm @Otca
                                      @otca
                                      • O Offline
                                        Otca @veye_xumm
                                        here is dmesg log.
                                        sudo dmesg| grep -i 'mvcam'
                                        Full DMESG Log:
                                        IMX264.OrinNX.txt
                                        i2cdetect -y -r 10
                                        VLC:
                                        vlc
                                        Opening in BLOCKING MODE
                                        DTB :
                                        TIMEOUT 30
                                        DEFAULT imx264
                                        MENU TITLE L4T boot options
                                        LABEL primary
                                              MENU LABEL primary kernel
                                              LINUX /boot/Image
                                              INITRD /boot/initrd
                                        LABEL imx264
                                              LINUX /boot/Image
                                              INITRD /boot/initrd
                                        O veye_xummV 2 Replies Last reply Reply Quote 0
                                        • O Offline
                                          Otca @Otca
                                          • O Offline
                                            Otca @Otca
                                            Dmesg Logs
                                            Dmesg_01.txt
                                            v4l2-ctl --list-formats-ext
                                            ioctl: VIDIOC_ENUM_FMT
                                            	Type: Video Capture
                                            	[0]: 'GREY' (8-bit Greyscale)
                                            		Size: Discrete 1920x1080
