    55 Posts 3 Posters 42.8k Views 2 Watching
      veye_xumm @Otca
      tegra234-p3767-camera-p3768-veye_mvcam-dual.dtbo
        veye_xumm @Otca
        @otca
        • O Offline
          Otca @veye_xumm
          TIMEOUT 50
          DEFAULT JetsonIO
          MENU TITLE L4T boot options
          LABEL primary
          MENU LABEL primary kernel
          LINUX /boot/Image
          INITRD /boot/initrd
          LABEL recovery
          LINUX /boot/Image
          INITRD /boot/initrd
          LINUX /boot/Image
          INITRD /boot/initrd
          LABEL Multi-User-With-GUI
          LINUX /boot/Image
          INITRD /boot/initrd
          LABEL JetsonIO
          LINUX /boot/Image
          INITRD /boot/initrd
          • O Offline
            Otca @veye_xumm
            		i2c@0 {
            			reg = <0x00>;
            			#address-cells = <0x01>;
            			#size-cells = <0x00>;
            			rbpcv3_mvcam_a@3b {
            				reg = <0x3b>;
            				devnode = "video0";
            				physical_w = "5.6";
            				physical_h = "3.1";
            				sensor_model = "mvcam";
            				use_sensor_mode_id = "false";
            				status = "okay";
            				phandle = <0x482>;
            				mode0 {
            					mclk_khz = "24000";
            					num_lanes = "2";
            					phy_mode = "DPHY";
            					discontinuous_clk = "yes";
            					dpcm_enable = "false";
            					cil_settletime = "0";
            					lane_polarity = "6";
            					active_w = "3088";
            					active_h = "2064";
            					mode_type = "raw";
            					csi_pixel_bit_depth = "8";
            					pixel_phase = "y8";
            					readout_orientation = "0";
            					line_length = "3088";
            					inherent_gain = "1";
            					mclk_multiplier = "2";
            					pix_clk_hz = "375000000";
            					gain_factor = "16";
            					framerate_factor = "1000000";
            					exposure_factor = "1000000";
            					min_gain_val = "16";
            					max_gain_val = "170";
            					step_gain_val = "1";
            					default_gain = "16";
            					min_hdr_ratio = "1";
            					max_hdr_ratio = "1";
            					min_framerate = "2000000";
            					max_framerate = "20000000";
            					step_framerate = "1";
            					min_exp_time = "13";
            					max_exp_time = "333333";
            					step_exp_time = "1";
            					default_exp_time = "2495";
            Property IMX264
            physical_w 8.390
            physical_h 7.066
            active_w 2432
            active_h 2048
            pixel_t RG 8,10,12
            max_gain_val 48
            step_gain_val 0.100
            max_framerate (2L08) 35.5
            max_framerate (2L10) 35.5
            max_framerate (2L12) 35.5
            Thanks for ur help ❤
            • O Offline
              Otca @Otca
              dmesg | grep -i 'fail'
              dmesg | grep -i 'i2c'
              dmesg | grep -i 'veye'
                veye_xumm @Otca
                @otca
                  veye_xumm @Otca
                  @otca
                  • O Offline
                    Otca @veye_xumm
                    • O Offline
                      Otca @Otca
                        veye_xumm @Otca
                        @otca
                        • O Offline
                          Otca @veye_xumm
                            veye_xumm @Otca
                            @otca
                            • O Offline
                              Otca @veye_xumm
                              • O Offline
                                Otca @Otca
                                Do u know this issue?
                                • O Offline
                                  Otca @Otca
                                    veye_xumm @Otca
                                    • O Offline
                                      Otca @veye_xumm
                                      i2cdetect -y -r 9
                                      70: -- -- -- -- -- -- -- --
                                      i2cdetect -y -r 10
                                      ls /sys/bus/i2c/drivers/
                                      extLinux Config
                                      LABEL imx264
                                         LINUX /boot/Image
                                         INITRD /boot/initrd
                                      Upgarde Jetson Jetpack 6
                                      sudo depmod
                                      tegra-camera.ko
                                        veye_xumm @Otca
                                        @otca
                                        veye_xummV O 2 Replies Last reply Reply Quote 0
                                          veye_xumm @veye_xumm
                                          @Otca
                                          • O Offline
                                            Otca @veye_xumm
                                            thanks for your guidance.
                                            The dmesg log is appended.
                                            MV-MIPI-IMX264.txt
