    55 Posts 3 Posters 42.8k Views 2 Watching
      veye_xumm @vitob
      @vitob We are working on the driver port and expect it to be done and released in a week.
      • V Offline
        vitob @veye_xumm
        @veye_xumm Thank you for replying. Expect for the new release.
          veye_xumm @vitob
          @vitob
          I've posted the drivers for Orin nano and Orin NX for Jetpack 6.0 as well as the supporting materials. Please refer to the following link.
          https://wiki.veye.cc/index.php/Nvidia_Jetson_Application_Note_Index
          O 1 Reply Last reply Reply Quote 1
          • O Offline
            Otca @veye_xumm
            @veye_xumm Hi i have read all the wiki and downloaded https://github.com/veyeimaging/nvidia_jetson_veye_bsp
            but I am still missing dtb file for MV-MIPI-IMX264.
            I have bought 4 of them and I have tried so many times. still I cannot make use of one of those.
            I have install all the drivers and other steps i just need dtb file
            OS: ubuntu 22.04
            jeton orin nano Jetpack6.0,L4T r36.3
            please help me
            thanks
            • O Offline
              Otca @Otca
              @otca
              cat /etc/nv_tegra_release
              R36 (release), REVISION: 3.0, GCID: 36191598, BOARD: generic, EABI: aarch64, DATE: Mon May 6 17:34:21 UTC 2024
              KERNEL_VARIANT: oot
              dmesg | grep -i 'fail'
              [ 5.067860] hid-generic: probe of 0003:1C4F:0202.0002 failed with error -22
              [ 9.577266] videodev: module verification failed: signature and/or required key missing - tainting kernel
              [ 11.795964] dce: dce_admin_setup_clients_ipc:561 Get queue info failed for [2]
              [ 12.536169] veye_mvcam: mvcam_read: Reading register 0x04 failed
              [ 12.536185] mvcam 9-0010: failed to read chip id
              [ 12.536190] mvcam 9-0010: mvcam_identify_module failed.
              [ 13.041253] veye_mvcam: mvcam_read: Reading register 0x04 failed
              [ 13.041269] mvcam 10-0010: failed to read chip id
              [ 13.041273] mvcam 10-0010: mvcam_identify_module failed.
              [ 16.965874] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
              dmesg | grep -i 'veye'
              [ 12.031976] mvcam 9-0010: veye mv series camera driver version: 01.01.04
              [ 12.539516] mvcam 10-0010: veye mv series camera driver version: 01.01.04
              dmesg | grep -i 'error'
              [ 9.363672] squashfs: SQUASHFS error: Xattrs in filesystem, these will be ignored
              [ 9.365895] squashfs: SQUASHFS error: Xattrs in filesystem, these will be ignored
              [ 9.369376] squashfs: SQUASHFS error: Xattrs in filesystem, these will be ignored
                veye_xumm @Otca
                From this prompt message, it looks like your driver and dtb are doing the right thing. But now i2c probe can't get the device.
                Please make sure your 5V dupont cable is plugged into the right place? I can't see it clearly from the picture.
                • O Offline
                  Otca @veye_xumm
                  5V dupon
                  Thnaks for fast replay
                  To double check the pin of IMX264 would u please tell me which one is 5V and which one is GND?
                  • O Offline
                    Otca @Otca
                    @otca I just checked the connection and I'm sure that 5V and GND connection are OK.
                    any idea what to do?
                    • O Offline
                      Otca @Otca
                      @otca let double check the DTB i must use.
                      My camera is MV-IMX264-M which one of these dtbo is the right one?
                      tegra234-camera-rbpcv3-csimx307.dtsi*
                      tegra234-camera-rbpcv3-cssc132.dtsi*
                      tegra234-camera-rbpcv3-veyecam2m.dtsi*
                      tegra234-camera-rbpcv3-veyeimx335.dtsi*
                      tegra234-camera-rbpcv3-veye_mvcam.dtsi*
                      tegra234-p3767-camera-p3768-csimx307-dual.dtbo*
                      tegra234-p3767-camera-p3768-csimx307-dual.dts*
                      tegra234-p3767-camera-p3768-cssc132-dual.dtbo*
                      tegra234-p3767-camera-p3768-cssc132-dual.dts*
                      tegra234-p3767-camera-p3768-raw_ar0234m-dual.dtbo*
                      tegra234-p3767-camera-p3768-raw_ar0234m-dual.dts*
                      tegra234-p3767-camera-p3768-raw_imx462m-dual.dtbo*
                      tegra234-p3767-camera-p3768-raw_imx462m-dual.dts*
                      tegra234-p3767-camera-p3768-veyecam2m-dual.dtbo*
                      tegra234-p3767-camera-p3768-veyecam2m-dual.dts*
                      tegra234-p3767-camera-p3768-veyeimx335-dual.dtbo*
                      tegra234-p3767-camera-p3768-veyeimx335-dual.dts*
                      tegra234-p3767-camera-p3768-veye_mvcam-dual.dtbo*
                      tegra234-p3767-camera-p3768-veye_mvcam-dual.dts*
                        veye_xumm @Otca
                          veye_xumm @Otca
                          @otca
                          • O Offline
                            Otca @veye_xumm
                            TIMEOUT 50
                            DEFAULT JetsonIO
                            MENU TITLE L4T boot options
                            LABEL primary
                            MENU LABEL primary kernel
                            LINUX /boot/Image
                            INITRD /boot/initrd
                            LABEL recovery
                            LINUX /boot/Image
                            INITRD /boot/initrd
                            LINUX /boot/Image
                            INITRD /boot/initrd
                            LABEL Multi-User-With-GUI
                            LINUX /boot/Image
                            INITRD /boot/initrd
                            LABEL JetsonIO
                            LINUX /boot/Image
                            INITRD /boot/initrd
                            • O Offline
                              Otca @veye_xumm
                              		i2c@0 {
                              			reg = <0x00>;
                              			#address-cells = <0x01>;
                              			#size-cells = <0x00>;
                              			rbpcv3_mvcam_a@3b {
                              				reg = <0x3b>;
                              				devnode = "video0";
                              				physical_w = "5.6";
                              				physical_h = "3.1";
                              				sensor_model = "mvcam";
                              				use_sensor_mode_id = "false";
                              				status = "okay";
                              				phandle = <0x482>;
                              				mode0 {
                              					mclk_khz = "24000";
                              					num_lanes = "2";
                              					phy_mode = "DPHY";
                              					discontinuous_clk = "yes";
                              					dpcm_enable = "false";
                              					cil_settletime = "0";
                              					lane_polarity = "6";
                              					active_w = "3088";
                              					active_h = "2064";
                              					mode_type = "raw";
                              					csi_pixel_bit_depth = "8";
                              					pixel_phase = "y8";
                              					readout_orientation = "0";
                              					line_length = "3088";
                              					inherent_gain = "1";
                              					mclk_multiplier = "2";
                              					pix_clk_hz = "375000000";
                              					gain_factor = "16";
                              					framerate_factor = "1000000";
                              					exposure_factor = "1000000";
                              					min_gain_val = "16";
                              					max_gain_val = "170";
                              					step_gain_val = "1";
                              					default_gain = "16";
                              					min_hdr_ratio = "1";
                              					max_hdr_ratio = "1";
                              					min_framerate = "2000000";
                              					max_framerate = "20000000";
                              					step_framerate = "1";
                              					min_exp_time = "13";
                              					max_exp_time = "333333";
                              					step_exp_time = "1";
                              					default_exp_time = "2495";
                              Property IMX264
                              physical_w 8.390
                              physical_h 7.066
                              active_w 2432
                              active_h 2048
                              pixel_t RG 8,10,12
                              max_gain_val 48
                              step_gain_val 0.100
                              max_framerate (2L08) 35.5
                              max_framerate (2L10) 35.5
                              max_framerate (2L12) 35.5
                              Thanks for ur help ❤
                              • O Offline
                                Otca @Otca
                                dmesg | grep -i 'i2c'
                                  veye_xumm @Otca
                                  @otca
                                    veye_xumm @Otca
                                    @otca
                                    • O Offline
                                      Otca @veye_xumm
                                      • O Offline
                                        Otca @Otca
                                          veye_xumm @Otca
                                          @otca
                                          • O Offline
                                            Otca @veye_xumm
