    55 Posts 3 Posters 42.8k Views 2 Watching
      veye_xumm @vitob
      @vitob
      I've posted the drivers for Orin nano and Orin NX for Jetpack 6.0 as well as the supporting materials. Please refer to the following link.
      https://wiki.veye.cc/index.php/Nvidia_Jetson_Application_Note_Index
      O 1 Reply Last reply Reply Quote 1
      • O Offline
        Otca @veye_xumm
        @veye_xumm Hi i have read all the wiki and downloaded https://github.com/veyeimaging/nvidia_jetson_veye_bsp
        but I am still missing dtb file for MV-MIPI-IMX264.
        I have bought 4 of them and I have tried so many times. still I cannot make use of one of those.
        I have install all the drivers and other steps i just need dtb file
        OS: ubuntu 22.04
        jeton orin nano Jetpack6.0,L4T r36.3
        please help me
        thanks
        • O Offline
          Otca @Otca
          @otca
          cat /etc/nv_tegra_release
          R36 (release), REVISION: 3.0, GCID: 36191598, BOARD: generic, EABI: aarch64, DATE: Mon May 6 17:34:21 UTC 2024
          KERNEL_VARIANT: oot
          dmesg | grep -i 'fail'
          [ 5.067860] hid-generic: probe of 0003:1C4F:0202.0002 failed with error -22
          [ 9.577266] videodev: module verification failed: signature and/or required key missing - tainting kernel
          [ 11.795964] dce: dce_admin_setup_clients_ipc:561 Get queue info failed for [2]
          [ 12.536169] veye_mvcam: mvcam_read: Reading register 0x04 failed
          [ 12.536185] mvcam 9-0010: failed to read chip id
          [ 12.536190] mvcam 9-0010: mvcam_identify_module failed.
          [ 13.041253] veye_mvcam: mvcam_read: Reading register 0x04 failed
          [ 13.041269] mvcam 10-0010: failed to read chip id
          [ 13.041273] mvcam 10-0010: mvcam_identify_module failed.
          [ 16.965874] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
          dmesg | grep -i 'veye'
          [ 12.031976] mvcam 9-0010: veye mv series camera driver version: 01.01.04
          [ 12.539516] mvcam 10-0010: veye mv series camera driver version: 01.01.04
          dmesg | grep -i 'error'
          [ 9.363672] squashfs: SQUASHFS error: Xattrs in filesystem, these will be ignored
          [ 9.365895] squashfs: SQUASHFS error: Xattrs in filesystem, these will be ignored
          [ 9.369376] squashfs: SQUASHFS error: Xattrs in filesystem, these will be ignored
            veye_xumm @Otca
            From this prompt message, it looks like your driver and dtb are doing the right thing. But now i2c probe can't get the device.
            Please make sure your 5V dupont cable is plugged into the right place? I can't see it clearly from the picture.
            • O Offline
              Otca @veye_xumm
              5V dupon
              Thnaks for fast replay
              To double check the pin of IMX264 would u please tell me which one is 5V and which one is GND?
              • O Offline
                Otca @Otca
                @otca I just checked the connection and I'm sure that 5V and GND connection are OK.
                any idea what to do?
                • O Offline
                  Otca @Otca
                  @otca let double check the DTB i must use.
                  My camera is MV-IMX264-M which one of these dtbo is the right one?
                  tegra234-camera-rbpcv3-csimx307.dtsi*
                  tegra234-camera-rbpcv3-cssc132.dtsi*
                  tegra234-camera-rbpcv3-veyecam2m.dtsi*
                  tegra234-camera-rbpcv3-veyeimx335.dtsi*
                  tegra234-camera-rbpcv3-veye_mvcam.dtsi*
                  tegra234-p3767-camera-p3768-csimx307-dual.dtbo*
                  tegra234-p3767-camera-p3768-csimx307-dual.dts*
                  tegra234-p3767-camera-p3768-cssc132-dual.dtbo*
                  tegra234-p3767-camera-p3768-cssc132-dual.dts*
                  tegra234-p3767-camera-p3768-raw_ar0234m-dual.dtbo*
                  tegra234-p3767-camera-p3768-raw_ar0234m-dual.dts*
                  tegra234-p3767-camera-p3768-raw_imx462m-dual.dtbo*
                  tegra234-p3767-camera-p3768-raw_imx462m-dual.dts*
                  tegra234-p3767-camera-p3768-veyecam2m-dual.dtbo*
                  tegra234-p3767-camera-p3768-veyecam2m-dual.dts*
                  tegra234-p3767-camera-p3768-veyeimx335-dual.dtbo*
                  tegra234-p3767-camera-p3768-veyeimx335-dual.dts*
                  tegra234-p3767-camera-p3768-veye_mvcam-dual.dtbo*
                  tegra234-p3767-camera-p3768-veye_mvcam-dual.dts*
                    veye_xumm @Otca
                      veye_xumm @Otca
                      @otca
                      • O Offline
                        Otca @veye_xumm
                        TIMEOUT 50
                        DEFAULT JetsonIO
                        MENU TITLE L4T boot options
                        LABEL primary
                        MENU LABEL primary kernel
                        LINUX /boot/Image
                        INITRD /boot/initrd
                        LABEL recovery
                        LINUX /boot/Image
                        INITRD /boot/initrd
                        LINUX /boot/Image
                        INITRD /boot/initrd
                        LABEL Multi-User-With-GUI
                        LINUX /boot/Image
                        INITRD /boot/initrd
                        LABEL JetsonIO
                        LINUX /boot/Image
                        INITRD /boot/initrd
                        • O Offline
                          Otca @veye_xumm
                          		i2c@0 {
                          			reg = <0x00>;
                          			#address-cells = <0x01>;
                          			#size-cells = <0x00>;
                          			rbpcv3_mvcam_a@3b {
                          				reg = <0x3b>;
                          				devnode = "video0";
                          				physical_w = "5.6";
                          				physical_h = "3.1";
                          				sensor_model = "mvcam";
                          				use_sensor_mode_id = "false";
                          				status = "okay";
                          				phandle = <0x482>;
                          				mode0 {
                          					mclk_khz = "24000";
                          					num_lanes = "2";
                          					phy_mode = "DPHY";
                          					discontinuous_clk = "yes";
                          					dpcm_enable = "false";
                          					cil_settletime = "0";
                          					lane_polarity = "6";
                          					active_w = "3088";
                          					active_h = "2064";
                          					mode_type = "raw";
                          					csi_pixel_bit_depth = "8";
                          					pixel_phase = "y8";
                          					readout_orientation = "0";
                          					line_length = "3088";
                          					inherent_gain = "1";
                          					mclk_multiplier = "2";
                          					pix_clk_hz = "375000000";
                          					gain_factor = "16";
                          					framerate_factor = "1000000";
                          					exposure_factor = "1000000";
                          					min_gain_val = "16";
                          					max_gain_val = "170";
                          					step_gain_val = "1";
                          					default_gain = "16";
                          					min_hdr_ratio = "1";
                          					max_hdr_ratio = "1";
                          					min_framerate = "2000000";
                          					max_framerate = "20000000";
                          					step_framerate = "1";
                          					min_exp_time = "13";
                          					max_exp_time = "333333";
                          					step_exp_time = "1";
                          					default_exp_time = "2495";
                          Property IMX264
                          physical_w 8.390
                          physical_h 7.066
                          active_w 2432
                          active_h 2048
                          pixel_t RG 8,10,12
                          max_gain_val 48
                          step_gain_val 0.100
                          max_framerate (2L08) 35.5
                          max_framerate (2L10) 35.5
                          max_framerate (2L12) 35.5
                          Thanks for ur help ❤
                          • O Offline
                            Otca @Otca
                            dmesg | grep -i 'i2c'
                              veye_xumm @Otca
                              @otca
                                veye_xumm @Otca
                                @otca
                                • O Offline
                                  Otca @veye_xumm
                                  • O Offline
                                    Otca @Otca
                                      veye_xumm @Otca
                                      @otca
                                      • O Offline
                                        Otca @veye_xumm
                                          veye_xumm @Otca
                                          @otca
                                          • O Offline
                                            Otca @veye_xumm
