    55 Posts 3 Posters 42.8k Views 2 Watching
    • O Offline
      Otca @Otca
      @otca
      cat /etc/nv_tegra_release
      R36 (release), REVISION: 3.0, GCID: 36191598, BOARD: generic, EABI: aarch64, DATE: Mon May 6 17:34:21 UTC 2024
      KERNEL_VARIANT: oot
      dmesg | grep -i 'fail'
      [ 5.067860] hid-generic: probe of 0003:1C4F:0202.0002 failed with error -22
      [ 9.577266] videodev: module verification failed: signature and/or required key missing - tainting kernel
      [ 11.795964] dce: dce_admin_setup_clients_ipc:561 Get queue info failed for [2]
      [ 12.536169] veye_mvcam: mvcam_read: Reading register 0x04 failed
      [ 12.536185] mvcam 9-0010: failed to read chip id
      [ 12.536190] mvcam 9-0010: mvcam_identify_module failed.
      [ 13.041253] veye_mvcam: mvcam_read: Reading register 0x04 failed
      [ 13.041269] mvcam 10-0010: failed to read chip id
      [ 13.041273] mvcam 10-0010: mvcam_identify_module failed.
      [ 16.965874] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
      dmesg | grep -i 'veye'
      [ 12.031976] mvcam 9-0010: veye mv series camera driver version: 01.01.04
      [ 12.539516] mvcam 10-0010: veye mv series camera driver version: 01.01.04
      dmesg | grep -i 'error'
      [ 9.363672] squashfs: SQUASHFS error: Xattrs in filesystem, these will be ignored
      [ 9.365895] squashfs: SQUASHFS error: Xattrs in filesystem, these will be ignored
      [ 9.369376] squashfs: SQUASHFS error: Xattrs in filesystem, these will be ignored
        veye_xumm @Otca
        From this prompt message, it looks like your driver and dtb are doing the right thing. But now i2c probe can't get the device.
        Please make sure your 5V dupont cable is plugged into the right place? I can't see it clearly from the picture.
        • O Offline
          Otca @veye_xumm
          5V dupon
          Thnaks for fast replay
          To double check the pin of IMX264 would u please tell me which one is 5V and which one is GND?
          • O Offline
            Otca @Otca
            @otca I just checked the connection and I'm sure that 5V and GND connection are OK.
            any idea what to do?
            • O Offline
              Otca @Otca
              @otca let double check the DTB i must use.
              My camera is MV-IMX264-M which one of these dtbo is the right one?
              tegra234-camera-rbpcv3-csimx307.dtsi*
              tegra234-camera-rbpcv3-cssc132.dtsi*
              tegra234-camera-rbpcv3-veyecam2m.dtsi*
              tegra234-camera-rbpcv3-veyeimx335.dtsi*
              tegra234-camera-rbpcv3-veye_mvcam.dtsi*
              tegra234-p3767-camera-p3768-csimx307-dual.dtbo*
              tegra234-p3767-camera-p3768-csimx307-dual.dts*
              tegra234-p3767-camera-p3768-cssc132-dual.dtbo*
              tegra234-p3767-camera-p3768-cssc132-dual.dts*
              tegra234-p3767-camera-p3768-raw_ar0234m-dual.dtbo*
              tegra234-p3767-camera-p3768-raw_ar0234m-dual.dts*
              tegra234-p3767-camera-p3768-raw_imx462m-dual.dtbo*
              tegra234-p3767-camera-p3768-raw_imx462m-dual.dts*
              tegra234-p3767-camera-p3768-veyecam2m-dual.dtbo*
              tegra234-p3767-camera-p3768-veyecam2m-dual.dts*
              tegra234-p3767-camera-p3768-veyeimx335-dual.dtbo*
              tegra234-p3767-camera-p3768-veyeimx335-dual.dts*
              tegra234-p3767-camera-p3768-veye_mvcam-dual.dtbo*
              tegra234-p3767-camera-p3768-veye_mvcam-dual.dts*
                veye_xumm @Otca
                  veye_xumm @Otca
                  @otca
                  • O Offline
                    Otca @veye_xumm
                    TIMEOUT 50
                    DEFAULT JetsonIO
                    MENU TITLE L4T boot options
                    LABEL primary
                    MENU LABEL primary kernel
                    LINUX /boot/Image
                    INITRD /boot/initrd
                    LABEL recovery
                    LINUX /boot/Image
                    INITRD /boot/initrd
                    LINUX /boot/Image
                    INITRD /boot/initrd
                    LABEL Multi-User-With-GUI
                    LINUX /boot/Image
                    INITRD /boot/initrd
                    LABEL JetsonIO
                    LINUX /boot/Image
                    INITRD /boot/initrd
                    • O Offline
                      Otca @veye_xumm
                      		i2c@0 {
                      			reg = <0x00>;
                      			#address-cells = <0x01>;
                      			#size-cells = <0x00>;
                      			rbpcv3_mvcam_a@3b {
                      				reg = <0x3b>;
                      				devnode = "video0";
                      				physical_w = "5.6";
                      				physical_h = "3.1";
                      				sensor_model = "mvcam";
                      				use_sensor_mode_id = "false";
                      				status = "okay";
                      				phandle = <0x482>;
                      				mode0 {
                      					mclk_khz = "24000";
                      					num_lanes = "2";
                      					phy_mode = "DPHY";
                      					discontinuous_clk = "yes";
                      					dpcm_enable = "false";
                      					cil_settletime = "0";
                      					lane_polarity = "6";
                      					active_w = "3088";
                      					active_h = "2064";
                      					mode_type = "raw";
                      					csi_pixel_bit_depth = "8";
                      					pixel_phase = "y8";
                      					readout_orientation = "0";
                      					line_length = "3088";
                      					inherent_gain = "1";
                      					mclk_multiplier = "2";
                      					pix_clk_hz = "375000000";
                      					gain_factor = "16";
                      					framerate_factor = "1000000";
                      					exposure_factor = "1000000";
                      					min_gain_val = "16";
                      					max_gain_val = "170";
                      					step_gain_val = "1";
                      					default_gain = "16";
                      					min_hdr_ratio = "1";
                      					max_hdr_ratio = "1";
                      					min_framerate = "2000000";
                      					max_framerate = "20000000";
                      					step_framerate = "1";
                      					min_exp_time = "13";
                      					max_exp_time = "333333";
                      					step_exp_time = "1";
                      					default_exp_time = "2495";
                      Property IMX264
                      physical_w 8.390
                      physical_h 7.066
                      active_w 2432
                      active_h 2048
                      pixel_t RG 8,10,12
                      max_gain_val 48
                      step_gain_val 0.100
                      max_framerate (2L08) 35.5
                      max_framerate (2L10) 35.5
                      max_framerate (2L12) 35.5
                      Thanks for ur help ❤
                      • O Offline
                        Otca @Otca
                        dmesg | grep -i 'i2c'
                          veye_xumm @Otca
                          @otca
                            veye_xumm @Otca
                            @otca
                            • O Offline
                              Otca @veye_xumm
                              • O Offline
                                Otca @Otca
                                  veye_xumm @Otca
                                  @otca
                                  • O Offline
                                    Otca @veye_xumm
                                      veye_xumm @Otca
                                      @otca
                                      • O Offline
                                        Otca @veye_xumm
                                        • O Offline
                                          Otca @Otca
                                          Do u know this issue?
                                          • O Offline
                                            Otca @Otca
