    55 Posts 3 Posters 42.8k Views 2 Watching
    • O Offline
      Otca @Otca
      dmesg | grep -i 'fail'
      dmesg | grep -i 'i2c'
      dmesg | grep -i 'veye'
        veye_xumm @Otca
        @otca
          veye_xumm @Otca
          @otca
          • O Offline
            Otca @veye_xumm
            • O Offline
              Otca @Otca
                veye_xumm @Otca
                @otca
                • O Offline
                  Otca @veye_xumm
                    veye_xumm @Otca
                    @otca
                    • O Offline
                      Otca @veye_xumm
                      • O Offline
                        Otca @Otca
                        Do u know this issue?
                        • O Offline
                          Otca @Otca
                            veye_xumm @Otca
                            • O Offline
                              Otca @veye_xumm
                              i2cdetect -y -r 9
                              70: -- -- -- -- -- -- -- --
                              i2cdetect -y -r 10
                              ls /sys/bus/i2c/drivers/
                              extLinux Config
                              LABEL imx264
                                 LINUX /boot/Image
                                 INITRD /boot/initrd
                              Upgarde Jetson Jetpack 6
                              sudo depmod
                              tegra-camera.ko
                                veye_xumm @Otca
                                @otca
                                veye_xummV O 2 Replies Last reply Reply Quote 0
                                  veye_xumm @veye_xumm
                                  @Otca
                                  • O Offline
                                    Otca @veye_xumm
                                    thanks for your guidance.
                                    The dmesg log is appended.
                                    MV-MIPI-IMX264.txt
                                      veye_xumm @Otca
                                      • O Offline
                                        Otca @veye_xumm
                                        Thanks alot
                                          veye_xumm @Otca
                                          @otca
                                          • O Offline
                                            Otca @veye_xumm
                                            here is dmesg log.
                                            sudo dmesg| grep -i 'mvcam'
                                            Full DMESG Log:
                                            IMX264.OrinNX.txt
                                            i2cdetect -y -r 10
                                            VLC:
                                            vlc
                                            Opening in BLOCKING MODE
                                            DTB :
                                            TIMEOUT 30
                                            DEFAULT imx264
                                            MENU TITLE L4T boot options
                                            LABEL primary
                                                  MENU LABEL primary kernel
                                                  LINUX /boot/Image
                                                  INITRD /boot/initrd
                                            LABEL imx264
                                                  LINUX /boot/Image
                                                  INITRD /boot/initrd
                                            O veye_xummV 2 Replies Last reply Reply Quote 0
