    55 Posts 3 Posters 39.1k Views 2 Watching
    • O Offline
      Otca @Otca
      @otca I just checked the connection and I'm sure that 5V and GND connection are OK.
      any idea what to do?
      • O Offline
        Otca @Otca
        @otca let double check the DTB i must use.
        My camera is MV-IMX264-M which one of these dtbo is the right one?
        tegra234-camera-rbpcv3-csimx307.dtsi*
        tegra234-camera-rbpcv3-cssc132.dtsi*
        tegra234-camera-rbpcv3-veyecam2m.dtsi*
        tegra234-camera-rbpcv3-veyeimx335.dtsi*
        tegra234-camera-rbpcv3-veye_mvcam.dtsi*
        tegra234-p3767-camera-p3768-csimx307-dual.dtbo*
        tegra234-p3767-camera-p3768-csimx307-dual.dts*
        tegra234-p3767-camera-p3768-cssc132-dual.dtbo*
        tegra234-p3767-camera-p3768-cssc132-dual.dts*
        tegra234-p3767-camera-p3768-raw_ar0234m-dual.dtbo*
        tegra234-p3767-camera-p3768-raw_ar0234m-dual.dts*
        tegra234-p3767-camera-p3768-raw_imx462m-dual.dtbo*
        tegra234-p3767-camera-p3768-raw_imx462m-dual.dts*
        tegra234-p3767-camera-p3768-veyecam2m-dual.dtbo*
        tegra234-p3767-camera-p3768-veyecam2m-dual.dts*
        tegra234-p3767-camera-p3768-veyeimx335-dual.dtbo*
        tegra234-p3767-camera-p3768-veyeimx335-dual.dts*
        tegra234-p3767-camera-p3768-veye_mvcam-dual.dtbo*
        tegra234-p3767-camera-p3768-veye_mvcam-dual.dts*
          veye_xumm @Otca
            veye_xumm @Otca
            @otca
            • O Offline
              Otca @veye_xumm
              TIMEOUT 50
              DEFAULT JetsonIO
              MENU TITLE L4T boot options
              LABEL primary
              MENU LABEL primary kernel
              LINUX /boot/Image
              INITRD /boot/initrd
              LABEL recovery
              LINUX /boot/Image
              INITRD /boot/initrd
              LINUX /boot/Image
              INITRD /boot/initrd
              LABEL Multi-User-With-GUI
              LINUX /boot/Image
              INITRD /boot/initrd
              LABEL JetsonIO
              LINUX /boot/Image
              INITRD /boot/initrd
              • O Offline
                Otca @veye_xumm
                		i2c@0 {
                			reg = <0x00>;
                			#address-cells = <0x01>;
                			#size-cells = <0x00>;
                			rbpcv3_mvcam_a@3b {
                				reg = <0x3b>;
                				devnode = "video0";
                				physical_w = "5.6";
                				physical_h = "3.1";
                				sensor_model = "mvcam";
                				use_sensor_mode_id = "false";
                				status = "okay";
                				phandle = <0x482>;
                				mode0 {
                					mclk_khz = "24000";
                					num_lanes = "2";
                					phy_mode = "DPHY";
                					discontinuous_clk = "yes";
                					dpcm_enable = "false";
                					cil_settletime = "0";
                					lane_polarity = "6";
                					active_w = "3088";
                					active_h = "2064";
                					mode_type = "raw";
                					csi_pixel_bit_depth = "8";
                					pixel_phase = "y8";
                					readout_orientation = "0";
                					line_length = "3088";
                					inherent_gain = "1";
                					mclk_multiplier = "2";
                					pix_clk_hz = "375000000";
                					gain_factor = "16";
                					framerate_factor = "1000000";
                					exposure_factor = "1000000";
                					min_gain_val = "16";
                					max_gain_val = "170";
                					step_gain_val = "1";
                					default_gain = "16";
                					min_hdr_ratio = "1";
                					max_hdr_ratio = "1";
                					min_framerate = "2000000";
                					max_framerate = "20000000";
                					step_framerate = "1";
                					min_exp_time = "13";
                					max_exp_time = "333333";
                					step_exp_time = "1";
                					default_exp_time = "2495";
                Property IMX264
                physical_w 8.390
                physical_h 7.066
                active_w 2432
                active_h 2048
                pixel_t RG 8,10,12
                max_gain_val 48
                step_gain_val 0.100
                max_framerate (2L08) 35.5
                max_framerate (2L10) 35.5
                max_framerate (2L12) 35.5
                Thanks for ur help ❤
                • O Offline
                  Otca @Otca
                  dmesg | grep -i 'fail'
                  dmesg | grep -i 'i2c'
                  dmesg | grep -i 'veye'
                    veye_xumm @Otca
                    @otca
                      veye_xumm @Otca
                      @otca
                      • O Offline
                        Otca @veye_xumm
                        • O Offline
                          Otca @Otca
                            veye_xumm @Otca
                            @otca
                            • O Offline
                              Otca @veye_xumm
                                veye_xumm @Otca
                                @otca
                                • O Offline
                                  Otca @veye_xumm
                                  • O Offline
                                    Otca @Otca
                                    Do u know this issue?
                                    • O Offline
                                      Otca @Otca
                                        veye_xumm @Otca
                                        • O Offline
                                          Otca @veye_xumm
                                          i2cdetect -y -r 9
                                          70: -- -- -- -- -- -- -- --
                                          i2cdetect -y -r 10
                                          ls /sys/bus/i2c/drivers/
                                          extLinux Config
                                          LABEL imx264
                                             LINUX /boot/Image
                                             INITRD /boot/initrd
                                          Upgarde Jetson Jetpack 6
                                          sudo depmod
                                          tegra-camera.ko
                                            veye_xumm @Otca
                                            @otca
                                            veye_xummV O 2 Replies Last reply Reply Quote 0
