    55 Posts 3 Posters 38.3k Views 2 Watching
    • V Offline
      vitob
      NVidia Jetson Jetpack 6.0 is now officially available. When will the camera source codes be available for JP6 then? Thanks.
        veye_xumm @vitob
        @vitob We are working on the driver port and expect it to be done and released in a week.
        • V Offline
          vitob @veye_xumm
          @veye_xumm Thank you for replying. Expect for the new release.
            veye_xumm @vitob
            @vitob
            I've posted the drivers for Orin nano and Orin NX for Jetpack 6.0 as well as the supporting materials. Please refer to the following link.
            https://wiki.veye.cc/index.php/Nvidia_Jetson_Application_Note_Index
            O 1 Reply Last reply Reply Quote 1
            • O Offline
              Otca @veye_xumm
              @veye_xumm Hi i have read all the wiki and downloaded https://github.com/veyeimaging/nvidia_jetson_veye_bsp
              but I am still missing dtb file for MV-MIPI-IMX264.
              I have bought 4 of them and I have tried so many times. still I cannot make use of one of those.
              I have install all the drivers and other steps i just need dtb file
              OS: ubuntu 22.04
              jeton orin nano Jetpack6.0,L4T r36.3
              please help me
              thanks
              • O Offline
                Otca @Otca
                @otca
                cat /etc/nv_tegra_release
                R36 (release), REVISION: 3.0, GCID: 36191598, BOARD: generic, EABI: aarch64, DATE: Mon May 6 17:34:21 UTC 2024
                KERNEL_VARIANT: oot
                dmesg | grep -i 'fail'
                [ 5.067860] hid-generic: probe of 0003:1C4F:0202.0002 failed with error -22
                [ 9.577266] videodev: module verification failed: signature and/or required key missing - tainting kernel
                [ 11.795964] dce: dce_admin_setup_clients_ipc:561 Get queue info failed for [2]
                [ 12.536169] veye_mvcam: mvcam_read: Reading register 0x04 failed
                [ 12.536185] mvcam 9-0010: failed to read chip id
                [ 12.536190] mvcam 9-0010: mvcam_identify_module failed.
                [ 13.041253] veye_mvcam: mvcam_read: Reading register 0x04 failed
                [ 13.041269] mvcam 10-0010: failed to read chip id
                [ 13.041273] mvcam 10-0010: mvcam_identify_module failed.
                [ 16.965874] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
                dmesg | grep -i 'veye'
                [ 12.031976] mvcam 9-0010: veye mv series camera driver version: 01.01.04
                [ 12.539516] mvcam 10-0010: veye mv series camera driver version: 01.01.04
                dmesg | grep -i 'error'
                [ 9.363672] squashfs: SQUASHFS error: Xattrs in filesystem, these will be ignored
                [ 9.365895] squashfs: SQUASHFS error: Xattrs in filesystem, these will be ignored
                [ 9.369376] squashfs: SQUASHFS error: Xattrs in filesystem, these will be ignored
                  veye_xumm @Otca
                  From this prompt message, it looks like your driver and dtb are doing the right thing. But now i2c probe can't get the device.
                  Please make sure your 5V dupont cable is plugged into the right place? I can't see it clearly from the picture.
                  • O Offline
                    Otca @veye_xumm
                    5V dupon
                    Thnaks for fast replay
                    To double check the pin of IMX264 would u please tell me which one is 5V and which one is GND?
                    • O Offline
                      Otca @Otca
                      @otca I just checked the connection and I'm sure that 5V and GND connection are OK.
                      any idea what to do?
                      • O Offline
                        Otca @Otca
                        @otca let double check the DTB i must use.
                        My camera is MV-IMX264-M which one of these dtbo is the right one?
                        tegra234-camera-rbpcv3-csimx307.dtsi*
                        tegra234-camera-rbpcv3-cssc132.dtsi*
                        tegra234-camera-rbpcv3-veyecam2m.dtsi*
                        tegra234-camera-rbpcv3-veyeimx335.dtsi*
                        tegra234-camera-rbpcv3-veye_mvcam.dtsi*
                        tegra234-p3767-camera-p3768-csimx307-dual.dtbo*
                        tegra234-p3767-camera-p3768-csimx307-dual.dts*
                        tegra234-p3767-camera-p3768-cssc132-dual.dtbo*
                        tegra234-p3767-camera-p3768-cssc132-dual.dts*
                        tegra234-p3767-camera-p3768-raw_ar0234m-dual.dtbo*
                        tegra234-p3767-camera-p3768-raw_ar0234m-dual.dts*
                        tegra234-p3767-camera-p3768-raw_imx462m-dual.dtbo*
                        tegra234-p3767-camera-p3768-raw_imx462m-dual.dts*
                        tegra234-p3767-camera-p3768-veyecam2m-dual.dtbo*
                        tegra234-p3767-camera-p3768-veyecam2m-dual.dts*
                        tegra234-p3767-camera-p3768-veyeimx335-dual.dtbo*
                        tegra234-p3767-camera-p3768-veyeimx335-dual.dts*
                        tegra234-p3767-camera-p3768-veye_mvcam-dual.dtbo*
                        tegra234-p3767-camera-p3768-veye_mvcam-dual.dts*
                          veye_xumm @Otca
                            veye_xumm @Otca
                            @otca
                            • O Offline
                              Otca @veye_xumm
                              TIMEOUT 50
                              DEFAULT JetsonIO
                              MENU TITLE L4T boot options
                              LABEL primary
                              MENU LABEL primary kernel
                              LINUX /boot/Image
                              INITRD /boot/initrd
                              LABEL recovery
                              LINUX /boot/Image
                              INITRD /boot/initrd
                              LINUX /boot/Image
                              INITRD /boot/initrd
                              LABEL Multi-User-With-GUI
                              LINUX /boot/Image
                              INITRD /boot/initrd
                              LABEL JetsonIO
                              LINUX /boot/Image
                              INITRD /boot/initrd
                              • O Offline
                                Otca @veye_xumm
                                		i2c@0 {
                                			reg = <0x00>;
                                			#address-cells = <0x01>;
                                			#size-cells = <0x00>;
                                			rbpcv3_mvcam_a@3b {
                                				reg = <0x3b>;
                                				devnode = "video0";
                                				physical_w = "5.6";
                                				physical_h = "3.1";
                                				sensor_model = "mvcam";
                                				use_sensor_mode_id = "false";
                                				status = "okay";
                                				phandle = <0x482>;
                                				mode0 {
                                					mclk_khz = "24000";
                                					num_lanes = "2";
                                					phy_mode = "DPHY";
                                					discontinuous_clk = "yes";
                                					dpcm_enable = "false";
                                					cil_settletime = "0";
                                					lane_polarity = "6";
                                					active_w = "3088";
                                					active_h = "2064";
                                					mode_type = "raw";
                                					csi_pixel_bit_depth = "8";
                                					pixel_phase = "y8";
                                					readout_orientation = "0";
                                					line_length = "3088";
                                					inherent_gain = "1";
                                					mclk_multiplier = "2";
                                					pix_clk_hz = "375000000";
                                					gain_factor = "16";
                                					framerate_factor = "1000000";
                                					exposure_factor = "1000000";
                                					min_gain_val = "16";
                                					max_gain_val = "170";
                                					step_gain_val = "1";
                                					default_gain = "16";
                                					min_hdr_ratio = "1";
                                					max_hdr_ratio = "1";
                                					min_framerate = "2000000";
                                					max_framerate = "20000000";
                                					step_framerate = "1";
                                					min_exp_time = "13";
                                					max_exp_time = "333333";
                                					step_exp_time = "1";
                                					default_exp_time = "2495";
                                Property IMX264
                                physical_w 8.390
                                physical_h 7.066
                                active_w 2432
                                active_h 2048
                                pixel_t RG 8,10,12
                                max_gain_val 48
                                step_gain_val 0.100
                                max_framerate (2L08) 35.5
                                max_framerate (2L10) 35.5
                                max_framerate (2L12) 35.5
                                Thanks for ur help ❤
                                • O Offline
                                  Otca @Otca
                                  dmesg | grep -i 'i2c'
                                    veye_xumm @Otca
                                    @otca
                                      veye_xumm @Otca
                                      @otca
                                      • O Offline
                                        Otca @veye_xumm
                                        • O Offline
                                          Otca @Otca
                                            veye_xumm @Otca
                                            @otca
