    55 Posts 3 Posters 40.8k Views 2 Watching
    • O Offline
      Otca @veye_xumm
      Thanks alot
        veye_xumm @Otca
        @otca
        • O Offline
          Otca @veye_xumm
          here is dmesg log.
          sudo dmesg| grep -i 'mvcam'
          Full DMESG Log:
          IMX264.OrinNX.txt
          i2cdetect -y -r 10
          70: -- -- -- -- -- -- -- --
          VLC:
          vlc
          Opening in BLOCKING MODE
          DTB :
          TIMEOUT 30
          DEFAULT imx264
          MENU TITLE L4T boot options
          LABEL primary
                MENU LABEL primary kernel
                LINUX /boot/Image
                INITRD /boot/initrd
          LABEL imx264
                LINUX /boot/Image
                INITRD /boot/initrd
          ls /sys/bus/i2c/drivers/
          O veye_xummV 2 Replies Last reply Reply Quote 0
          • O Offline
            Otca @Otca
            • O Offline
              Otca @Otca
              Dmesg Logs
              Dmesg_01.txt
              v4l2-ctl --list-formats-ext
              ioctl: VIDIOC_ENUM_FMT
              	Type: Video Capture
              	[0]: 'GREY' (8-bit Greyscale)
              		Size: Discrete 1920x1080
                veye_xumm @Otca
                @otca
                export WIDTH=2432
                export HEIGHT=2056
                export FPS=28
                v4l2-ctl --set-ctrl roi_x=0
                v4l2-ctl --set-ctrl roi_y=0
                • O Offline
                  Otca @veye_xumm
                  @veye_xumm Hi,
                  this is the results:
                  export WIDTH=2432
                  export HEIGHT=2056
                  export FPS=28
                  Dmesg log:
                  ####Dmesg of Last Line:
                  Full Dmesg log:
                  Dmesg.txt
                    veye_xumm @Otca
                    • O Offline
                      Otca @veye_xumm
                      sure!
                        veye_xumm @Otca
                        @otca
                        • O Offline
                          Otca @veye_xumm
                          r trigger mode is 0
                          • O Offline
                            Otca @Otca
                              veye_xumm @Otca
                              @otca You are welcome.
                              This issue is a bit strange.
                              • O Offline
                                Otca @veye_xumm
                                export WIDTH=1920
                                export HEIGHT=1080
                                export FPS=67
                                • O Offline
                                  Otca @Otca
                                  @otca Solved:
                                  • V Offline
                                    vitob
                                    • V Offline
                                      vitob
                                        veye_xumm @vitob
                                        @vitob
                                          veye_xumm @vitob
                                          • V Offline
                                            vitob @veye_xumm
                                            nvidia@ubuntu:/work/git_repo/nvidia_jetson_veye_bsp/mv_tools_jetson/i2c_tools$ ./mv_mipi_i2c.sh -r -f model -b 0
                                            model 0 not recognized
                                            nvidia@ubuntu:/work/git_repo/nvidia_jetson_veye_bsp/mv_tools_jetson/i2c_tools$ ./mv_mipi_i2c.sh -r -f model -b 1
                                            nvidia@ubuntu:/work/git_repo/nvidia_jetson_veye_bsp/mv_tools_jetson/i2c_tools$ ./mv_mipi_i2c_new.sh -r -f model -b 1
                                            NOT SUPPORTED!
                                            nvidia@ubuntu:/work/git_repo/nvidia_jetson_veye_bsp/mv_tools_jetson/i2c_tools$ ./mv_mipi_i2c_new.sh -r -f model -b 0
                                            NOT SUPPORTED!
