    55 Posts 3 Posters 39.1k Views 2 Watching
    • O Offline
      Otca @Otca
      Dmesg Logs
      Dmesg_01.txt
      v4l2-ctl --list-formats-ext
      ioctl: VIDIOC_ENUM_FMT
      	Type: Video Capture
      	[0]: 'GREY' (8-bit Greyscale)
      		Size: Discrete 1920x1080
        veye_xumm @Otca
        @otca
        export WIDTH=2432
        export HEIGHT=2056
        export FPS=28
        v4l2-ctl --set-ctrl roi_x=0
        v4l2-ctl --set-ctrl roi_y=0
        • O Offline
          Otca @veye_xumm
          @veye_xumm Hi,
          this is the results:
          export WIDTH=2432
          export HEIGHT=2056
          export FPS=28
          Dmesg log:
          ####Dmesg of Last Line:
          Full Dmesg log:
          Dmesg.txt
            veye_xumm @Otca
            • O Offline
              Otca @veye_xumm
              sure!
                veye_xumm @Otca
                @otca
                • O Offline
                  Otca @veye_xumm
                  r trigger mode is 0
                  • O Offline
                    Otca @Otca
                      veye_xumm @Otca
                      @otca You are welcome.
                      This issue is a bit strange.
                      • O Offline
                        Otca @veye_xumm
                        export WIDTH=1920
                        export HEIGHT=1080
                        export FPS=67
                        • O Offline
                          Otca @Otca
                          @otca Solved:
                          • V Offline
                            vitob
                            • V Offline
                              vitob
                                veye_xumm @vitob
                                @vitob
                                  veye_xumm @vitob
                                  • V Offline
                                    vitob @veye_xumm
                                    nvidia@ubuntu:/work/git_repo/nvidia_jetson_veye_bsp/mv_tools_jetson/i2c_tools$ ./mv_mipi_i2c.sh -r -f model -b 0
                                    model 0 not recognized
                                    nvidia@ubuntu:/work/git_repo/nvidia_jetson_veye_bsp/mv_tools_jetson/i2c_tools$ ./mv_mipi_i2c.sh -r -f model -b 1
                                    nvidia@ubuntu:/work/git_repo/nvidia_jetson_veye_bsp/mv_tools_jetson/i2c_tools$ ./mv_mipi_i2c_new.sh -r -f model -b 1
                                    NOT SUPPORTED!
                                    nvidia@ubuntu:/work/git_repo/nvidia_jetson_veye_bsp/mv_tools_jetson/i2c_tools$ ./mv_mipi_i2c_new.sh -r -f model -b 0
                                    NOT SUPPORTED!
                                    • V Offline
                                      vitob @veye_xumm
                                      @veye_xumm , let me confirm this, although I used sdkmanager to flash the board with nvidia native packages w/o issues.
                                      • V Offline
                                        vitob @vitob
                                        @vitob said in NVidia Jetson Jetpack 6 support?:
                                        In the meantime, can you help explain this question on tegra-camera.ko and v4l2-core/*.ko? Why they needs to be updated and where can I find the source code of them? Once updating them using the veye release .ko, will that affect other cameras (for example, I want to port/develop driver for another sensor myself)? Thanks.
                                          veye_xumm @vitob
                                          @vitob
                                          Please use -b 9 or -b 10 as an argument.
                                          For i2c bus number, please refer to this link above.
                                            veye_xumm @vitob
                                            These driver changes add support for RAW8 RAW10 RAW12 data types on the one hand, and externally triggered modes on the other.
                                            Their code reference:
                                            https://github.com/veyeimaging/nvidia_jetson_veye_bsp/tree/master/kernel_patch_4_mv/l4t-r36.3
                                            Compile step by step reference::
                                            https://wiki.veye.cc/index.php/VEYE_CS_Camera_source_for_Jetson
                                            1 Reply Last reply Reply Quote 1
