    55 Posts 3 Posters 39.9k Views 2 Watching
      veye_xumm @veye_xumm
      @Otca
      • O Offline
        Otca @veye_xumm
        thanks for your guidance.
        The dmesg log is appended.
        MV-MIPI-IMX264.txt
          veye_xumm @Otca
          • O Offline
            Otca @veye_xumm
            Thanks alot
              veye_xumm @Otca
              @otca
              • O Offline
                Otca @veye_xumm
                here is dmesg log.
                sudo dmesg| grep -i 'mvcam'
                Full DMESG Log:
                IMX264.OrinNX.txt
                i2cdetect -y -r 10
                70: -- -- -- -- -- -- -- --
                VLC:
                vlc
                Opening in BLOCKING MODE
                DTB :
                TIMEOUT 30
                DEFAULT imx264
                MENU TITLE L4T boot options
                LABEL primary
                      MENU LABEL primary kernel
                      LINUX /boot/Image
                      INITRD /boot/initrd
                LABEL imx264
                      LINUX /boot/Image
                      INITRD /boot/initrd
                ls /sys/bus/i2c/drivers/
                O veye_xummV 2 Replies Last reply Reply Quote 0
                • O Offline
                  Otca @Otca
                  • O Offline
                    Otca @Otca
                    Dmesg Logs
                    Dmesg_01.txt
                    v4l2-ctl --list-formats-ext
                    ioctl: VIDIOC_ENUM_FMT
                    	Type: Video Capture
                    	[0]: 'GREY' (8-bit Greyscale)
                    		Size: Discrete 1920x1080
                      veye_xumm @Otca
                      @otca
                      export WIDTH=2432
                      export HEIGHT=2056
                      export FPS=28
                      v4l2-ctl --set-ctrl roi_x=0
                      v4l2-ctl --set-ctrl roi_y=0
                      • O Offline
                        Otca @veye_xumm
                        @veye_xumm Hi,
                        this is the results:
                        export WIDTH=2432
                        export HEIGHT=2056
                        export FPS=28
                        Dmesg log:
                        ####Dmesg of Last Line:
                        Full Dmesg log:
                        Dmesg.txt
                          veye_xumm @Otca
                          • O Offline
                            Otca @veye_xumm
                            sure!
                              veye_xumm @Otca
                              @otca
                              • O Offline
                                Otca @veye_xumm
                                r trigger mode is 0
                                • O Offline
                                  Otca @Otca
                                    veye_xumm @Otca
                                    @otca You are welcome.
                                    This issue is a bit strange.
                                    • O Offline
                                      Otca @veye_xumm
                                      export WIDTH=1920
                                      export HEIGHT=1080
                                      export FPS=67
                                      • O Offline
                                        Otca @Otca
                                        @otca Solved:
                                        • V Offline
                                          vitob
                                          • V Offline
                                            vitob
