    55 Posts 3 Posters 42.8k Views 2 Watching
    • O Offline
      Otca @veye_xumm
      export WIDTH=1920
      export HEIGHT=1080
      export FPS=67
      • O Offline
        Otca @Otca
        @otca Solved:
        • V Offline
          vitob
          • V Offline
            vitob
              veye_xumm @vitob
              @vitob
                veye_xumm @vitob
                • V Offline
                  vitob @veye_xumm
                  nvidia@ubuntu:/work/git_repo/nvidia_jetson_veye_bsp/mv_tools_jetson/i2c_tools$ ./mv_mipi_i2c.sh -r -f model -b 0
                  model 0 not recognized
                  nvidia@ubuntu:/work/git_repo/nvidia_jetson_veye_bsp/mv_tools_jetson/i2c_tools$ ./mv_mipi_i2c.sh -r -f model -b 1
                  nvidia@ubuntu:/work/git_repo/nvidia_jetson_veye_bsp/mv_tools_jetson/i2c_tools$ ./mv_mipi_i2c_new.sh -r -f model -b 1
                  NOT SUPPORTED!
                  nvidia@ubuntu:/work/git_repo/nvidia_jetson_veye_bsp/mv_tools_jetson/i2c_tools$ ./mv_mipi_i2c_new.sh -r -f model -b 0
                  NOT SUPPORTED!
                  • V Offline
                    vitob @veye_xumm
                    @veye_xumm , let me confirm this, although I used sdkmanager to flash the board with nvidia native packages w/o issues.
                    • V Offline
                      vitob @vitob
                      @vitob said in NVidia Jetson Jetpack 6 support?:
                      In the meantime, can you help explain this question on tegra-camera.ko and v4l2-core/*.ko? Why they needs to be updated and where can I find the source code of them? Once updating them using the veye release .ko, will that affect other cameras (for example, I want to port/develop driver for another sensor myself)? Thanks.
                        veye_xumm @vitob
                        @vitob
                        Please use -b 9 or -b 10 as an argument.
                        For i2c bus number, please refer to this link above.
                          veye_xumm @vitob
                          These driver changes add support for RAW8 RAW10 RAW12 data types on the one hand, and externally triggered modes on the other.
                          Their code reference:
                          https://github.com/veyeimaging/nvidia_jetson_veye_bsp/tree/master/kernel_patch_4_mv/l4t-r36.3
                          Compile step by step reference::
                          https://wiki.veye.cc/index.php/VEYE_CS_Camera_source_for_Jetson
                          1 Reply Last reply Reply Quote 1
