• VEYE -MIPI-IMX462 - how to configure manual shutter&gain
    7
    @milank @milank said in VEYE -MIPI-IMX462 - how to configure manual shutter&gain: I assume FW cannot be upgraded by the user, right? yes
  • Seldom artefacts with veye-mipi-imx462
    8
    @milank I think it was RF interference on the FFC cable.
  • Asus Tinker Board 2S with MIPI-327E
    Z
    @veye_xumm Ok, thanks.
  • 0 Votes
    @nathan-sinclair said in using veye-mipi-327, unedited h264 video for display in html video element: Just a query about whether it's possible to be sending the h264 video from the mipi-327 camera unedited, so that it can be displayed in a video element on a web page. The way we are currently doing this, is using a library on the client side called jmuxer, which, through a websocket directly is able to display arducam cameras. Is there something similar with the mipi-327 camera as seen in libcamera-examples? Sorry, we now only have a similar demo available in legacy mode via gstreamer. http://wiki.veye.cc/index.php/VEYE-MIPI-290/327_for_Raspberry_Pi#veye_raspcam:_raspcam_alike_toolkits
  • VEYE-MIPI-IMX385 randomly flip the image upside down
    @thn The possible reason is that there are other signals on the i2c bus, causing the camera to misjudge. Is there any other device mounted on your i2c bus?
  • Different resolution & framerates for veye-mipi-imx462?
    @radiohound As far as I know, sony's datasheet is only open to corporate customers who have signed an NDA.
  • Use of VEYE-MIPI-IMX462 for astronomy applications under INDI
    1k Views
    R
    I'd be interested if you find anything out about this. Arducam has their own imx462 camera, but I notice it has a lot less ic chips on the back of it. So not sure their driver is going to help, or if they even have the ability to take a long exposure.
  • IMX296 连接树莓派系统
    @veye33 我们的资料都在wiki上。 http://wiki.veye.cc/index.php/MV-MIPI-IMX296M_Index part3.2--->part1.2。
  • IMX178M with Raspberry 3 and using trigger mode
    @alexxis
  • streaming veye mipi 327 camera over wifi
    @nathan-sinclair Sorry we haven't made any attempts at this.
  • CS-MIPI-IMX307测试Gstreamer发生错误
    1k Views
    @jh 看起来是nv3dsink的问题,你是远程登录到orin上执行的吗?
  • This topic is deleted!
    No one has replied
  • Veye327 on En715 Jetson Xavier nx dev kit
    1k Views
    No one has replied
  • 树莓派安装IMX385的驱动失败
    @maynight 换个播放器试一下,比如potplayer。我觉得录像文件本身应该是没问题的。 python这个我现在没有环境,回头搭建一个试试。你也可以先简单分析一下代码,这个代码挺简单的。
  • imx 327 veye and openCV
    1k Views
    @evgen Great!
  • 0 Votes
    1k Views
    S
    @veye_xumm 你好,imx622模组什么时候可以量产,我们需要一款1080P60帧的低照度摄像头模组。盼复。
  • MV-MIPI-IMX178M + khadas edge2
    M
    @veye_xumm Hi again! Well yeah, i made some research yesterday, after my question, and it become obvious, that it is not possible to direct connect not MV-MIPI-IMX178M nor existing adapter board to Khadas Edge2. Pin outs are not nearly the same. So i decided to make my own adapter board - it's quite easy. But i have some questions to avoid mistakes. So if i will properly connect all DATA lines, CLK and I2C to Edge2 and route all other signals to dedicated 2,54 header will it be enough to make it work? Power supply will be external and enable signal i want to give by simple switch. Can you give me minor instructions or, maybe, link that explains how to port your driver to another platform? Cause i never did that... Thanks in advance. PS: Did you ever work with CCD matrices? For some scientific cases they are preferable.
  • longest exposure time
    10
    M
    @veye_xumm Glad to hear that! I would like to test it as soon as possible.
  • I2C IR-day/night mode
    18
    5k Views
    @rob77 You are welcome.
  • veye-imx462. Is it possible to get data in raw format?
    @erm No, This camera has ISP built-in,it support UYVY output only.
