    2. VEYE MIPI camera
    Log in to post
    Load new posts
    • Recently Replied
    • Recently Created
    • Most Posts
    • Most Views
    • R
      VEYE-MIPI-IMX385 on jetson nano
      Watching Ignoring Scheduled Pinned Locked Moved
      21
      7k Views
      @rob77
    • P
      ISP vs NOISP
      1k Views
      @pimat correct.
    • N
      ISP defog
      1k Views
      P
      Is available in 327 or 462?
    • S
      VEYE-MIPI-IMX385 with Raspberry 4 no pictures
      10
      @salva OK
    • 1
      请问 IMX327 如何跟 FFmpeg 协同工作
      1k Views
      @veye_xumm 好的吧,感谢
    • S
      This topic is deleted!
      No one has replied
    • R
      veye_raspivid splits video in half and puts it together wrong
      1k Views
      @raphael correct
    • M
      IMX385 on Jetson Xavier NX JetPack5.01DP can't find camera
      25
      11k Views
      @maponarooo Thank you for the reminder, I've modified it. The file should have a tar.gz suffix instead of tgz.
    • D
      Camera VEYE-MIPI-IMX327S support on rk3399pro chips
      @dan_lionking Due to some problems with the bsp of rk3399. http://wiki.veye.cc/index.php/VEYE_MIPI_327_for_Nano_Pi_4_ubuntu#Exsiting_bugs After we have transport VEYE-MIPI-327 into rk3399, we found these problems and then abandoned the rk platform.
    • S
      imx327e coonectors CSI cable
      1k Views
      @siderat said in imx327e coonectors CSI cable: The camera has two connectors for connecting a cable. Upper wide, lower narrower. I am using PI. And I connect the cable to the top connector. Can you connect to the bottom connector too? Only one of these two connectors can be used at the same time.
    • T
      Is there any plan to support libcamera?
      25
      11k Views
      @thn Never mind, this can be ignored.
    • H
      About FFC connector of VEYE-MIPI-IMX355
      @hiro999 http://wiki.veye.cc/index.php/FFC_Cable
    • X
      SC132设置为hardware trigger模式若没收到触发信号会出现segfault
      1k Views
      @xzh 你好, 这个capture的功能并不是配套triggger模式的。其功能是从流模式下当前视频流中取出一帧图像。 使用trigger模式,建议使用D_start_yuv_stream函数,注册一个回调函数。然后就会一直处于等待状态。有触发信号之后,就会收到回调函数。
    • K
      VEYE-MIPI-327E preview 速度調整?
      21
      10k Views
      K
      @veye_xumm 好的謝謝您
    • N
      Inquiring about cameras for use with bananapi m2-zero
      1k Views
      @nathan-sinclair Sorry, no plans at this time.
    • T
      VEYE-MIPI-IMX385
      @thn said in VEYE-MIPI-IMX385: Is there support for legacy mode under bullseye 64 bit? No.
    • P
      VEYE327s Nvidia Jetson NX sensor not detected
      @photon-94 Since you are using 327S instead of 327E,please use dtb file in VEYE-MIPI-CAM2M dir.
    • J
      VEYE-MIPI-IMX462相机显示红色界面
      1k Views
      J
      @veye_xumm 好的,谢谢
    • S
      VEYE-MIPI-327S gstreamer issue
      S
      @veye_xumm FIXED! thank you!
    • K
      VEYE-MIPI-327E 使用gstreamer預覽畫面出現問題
      12
      4k Views
      @kuo 祝贺!
