SOLVED New Raspberry pi 5 support
Thanks for the update! Hope you can find a solution -
@natzguk
Plese check this release :
https://github.com/veyeimaging/raspberrypi_v4l2/releases/tag/v1.17
and this document:
https://wiki.veye.cc/index.php/V4L2_mode_for_Raspberry_Pi/ -
@veye_xumm Nice to see you have managed!
The second link is not works. There is the last slash must be removed in the URL.
I'm going to test it as soon as possible. -
I have successfully installed RPI5 driver veyecam2m.
I somehow managed to get uyuv frame from veye imx462 camera
using v4l2-ctl utility. (VLC is not working as mentioned).
But in my c++ project I use Linux v4l2 recommended procedure for capturing frames, and it doesn't work (It worked normally for RPI4).
VIDIOC_DQBUF fail, VIDIOC_STREAMON fail.
What is your recommendation for frame capturing algorythm? -
@vaa Before running your program, have you executed the
./media_setting_rpi5.sh veyecam2m
script? -
@veye_xumm Yes, I have. I did everything recommended.
Btw, I found VLC can preview ONLY if UYVY colorspace is set. It preview with wrong green-violet picture, but at least it does. -
@vaa Yes, indeed. That's what confuse me.
@veye_xumm Are you going to improve your driver's compatibility?
Also after every RPi restart have to run script: ./media_setting_rpi5.sh veyecam2m@veye_xumm any chances use configuration script ./veye_mipi_i2c.sh on RPi5?
@vaa
Here is a receipt how can I achived this:-
./veye_mipi_i2c.sh -b 6 -w -f yuvseq -p1 YUYV
./veye_mipi_i2c.sh -b 6 -w -f videoformat -p1 PAL
In my app open device /dev/video0 with following parameters:
width 1920;
height 1080;
field_format V4L2_FIELD_NONE
Some other applications like gstreamer only set pixel_format if you directly point to do this, this is why it works, but many others (e.g. trying to set default pixel_format) are not. -
@veye_xumm said in New Raspberry pi 5 support:
I think answer was "yes" but with parameter -b. I could not execute from bin dir because it compiled to another OS, so compile i2c_read, i2c_write from source code fixed my issue.
@veye_xumm thank you for help and support! -
@alex_ai You are welcome.
Some other applications like gstreamer only set pixel_format if you directly point to do this, this is why it works, but many others (e.g. trying to set default pixel_format) are not.Will you going to fix the issue?
