    相机驱动
    38 Posts 3 Posters 26.6k Views 1 Watching
      veye_xumm @lin
      @lin 相机是什么,主板是什么
        lin @veye_xumm
        @veye_xumm 主板roc-3588s-pc,相机是AR0234M
          veye_xumm @lin
          @lin 这个现在不支持isp_mainpath.
            lin
            那无法获取到经过isp处理后的图像吗?
              veye_xumm @lin
                lin @veye_xumm
                @veye_xumm好的
                  lin
                  &i2c7 {
                  status = "okay";
                      compatible = "veye1,mvcam1";
                      status = "okay";
                      reg = <0x3b>;
                      clocks = <&ext_cam_clk>;//?
                      clock-names = "xclk";
                      port {
                              data-lanes = <1 2>;
                    lin @lin
                      veye_xumm @lin
                        lin @veye_xumm
                          lin @lin
                            veye_xumm @lin
                              lin @veye_xumm
                                lin @lin
                                veye_xummV L 2 Replies Last reply Reply Quote 0
                                  veye_xumm @lin
                                    lin @veye_xumm
                                    @veye_xumm !是i2c7
                                    @lin said in 相机驱动:
                                      lin @lin
                                        veye_xumm @lin
                                        @lin said in 相机驱动:
                                        不好意思,我之前说的就是SYS_RSTn引脚的意思。
                                        拍一下你硬件连接的照片我看看。
                                          lin @veye_xumm
                                            veye_xumm @lin
                                            @lin said in 相机驱动:
