    相机采集图像阻塞
    37 Posts 4 Posters 28.9k Views 1 Watching
      lin @veye_xumm
      @veye_xumm said in 相机采集图像阻塞:
      另外你在i2c-7上面挂了两个相机?即便是这样,也没有必要做两个完全一致的ko插入到系统里面去
      我现在只在设备树添加一个相机,设备树中对相机时钟有要求吗?
        veye_xumm @lin
        @lin said in 相机采集图像阻塞:
        没有要求,相机自己有时钟。
        //***  CAM3 VEYE MVCAM Configuration Description  ****
        &csi2_dphy0_hw {
            status = "okay";
        &i2c7 {
            status = "okay";
            clock-frequency = <400000>;
            cam3_mvcam: cam3_mvcam@3b {
                compatible = "veye,mvcam";
                status = "okay";
                reg = <0x3b>;
                clocks = <&ext_cam_clk>;
                clock-names = "xclk";
                clock-frequency = <24000000>;
                pwdn-gpios = <&extio EXTIO_GPIO_P05 GPIO_ACTIVE_HIGH>;
                //enable-gpios = <&extio EXTIO_GPIO_P05 GPIO_ACTIVE_HIGH>;
                port {
                    cam3_mvcam_out: endpoint {
                        data-lanes = <1 2>;
        &csi2_dphy0 {
            status = "okay";
            ports {
                #address-cells = <1>;
                #size-cells = <0>;
                port@0 {
                    reg = <0>;
                    #size-cells = <0>;
                    mipi_in_ucam3: endpoint@1 {
                        reg = <1>;
                        remote-endpoint = <&cam3_mvcam_out>;
                        data-lanes = <1 2>;
                port@1 {
                    reg = <1>;
                    #size-cells = <0>;
                    mipi2_csi2_mipicsi0_out0: endpoint@0 {
                        reg = <0>;
        &mipi2_csi2 {
                status = "okay";
            ports {
                #size-cells = <0>;
                port@0 {
                    reg = <0>;
                    #size-cells = <0>;
                        reg = <1>;
                        remote-endpoint = <&mipi2_csi2_mipicsi0_out0>;
                port@1 {
                    reg = <1>;
                    #size-cells = <0>;
                        reg = <0>;
                        remote-endpoint = <&cif_mipi_lvds2>;
        &rkcif_mipi_lvds2 {
            status = "okay";
            port {
                cif_mipi_lvds2: endpoint {
        &rkcif_mipi_lvds2_sditf {
            status = "disabled";
          lin @veye_xumm
          @veye_xumm请问,你们调试的时候有遇到这种情况吗?没有数据流输出,一直阻塞 16a1f873-dc28-49a3-9b52-47e9ce0a76fb-image.png
            veye_xumm @lin
            @lin 你是否用的是外触发模式?
            查看一下dmesg是否有报错?
            确认一下dts中关于mipi接口配置是否正确。
              lin @veye_xumm
              内核打印信息:1.txt
              还有您说的mipi接口配置是指链路设置还是mipi_csi2节点设置?
                veye_xumm @lin
                整个数据通路都得配置好才行。
                  lin @veye_xumm
                    veye_xumm @lin
                    看你的拓扑图:
                    - entity 48: m00_b_mvcam 7-003b (1 pad, 1 link)
                            pad0: Source
                                    [fmt:Y8_1X8/1920x1200@100/6000 field:none]
                                    -> "rockchip-csi2-dphy1":0 [ENABLED]
                    你这边设定i2c-7接口配套的mipi硬件接口是:csi2-dphy1
                    真的是这样的吗?
                    我给你的我们调过的那个dts,用的可是csi2-dphy0啊!
                      lin @veye_xumm
                      i2c-7接口配套的mipi硬件接口
                        veye_xumm @lin
                        @lin 你是用的OK3588-C这个开发板吗?
                          lin @veye_xumm
                          @veye_xumm 是的
                            lin @lin
                              veye_xumm @lin
                              没有要求,相机自己有时钟。
                              你直接用这个dts,然后配合我们官方发布的驱动。
                              应该可以直接调通i2c-7这一路才对。
                                lin @veye_xumm
                                  veye_xumm @lin
                                  你用的相机型号是什么? 用哪个命令做的取图?
                                    lin @veye_xumm
                                      veye_xumm @lin
                                      应该跟这个没关系。
                                      你这个命令也没有问题。
                                        lin @veye_xumm
                                        自己画的转接板
                                          veye_xumm @lin
                                            lin @veye_xumm
                                            功率不够需要怎么解决,外加电源吗?功率需达到多少可以呢?
