    相机采集图像阻塞
    37 Posts 4 Posters 28.9k Views 1 Watching
      veye_xumm @lin
      @lin said in 相机采集图像阻塞:
      我现在只在设备树添加一个相机,设备树中对相机时钟有要求吗?
      没有要求,相机自己有时钟。
      //***  CAM3 VEYE MVCAM Configuration Description  ****
      &csi2_dphy0_hw {
          status = "okay";
      &i2c7 {
          status = "okay";
          clock-frequency = <400000>;
          cam3_mvcam: cam3_mvcam@3b {
              compatible = "veye,mvcam";
              status = "okay";
              reg = <0x3b>;
              clocks = <&ext_cam_clk>;
              clock-names = "xclk";
              clock-frequency = <24000000>;
              pwdn-gpios = <&extio EXTIO_GPIO_P05 GPIO_ACTIVE_HIGH>;
              //enable-gpios = <&extio EXTIO_GPIO_P05 GPIO_ACTIVE_HIGH>;
              port {
                  cam3_mvcam_out: endpoint {
                      data-lanes = <1 2>;
      &csi2_dphy0 {
          status = "okay";
          ports {
              #address-cells = <1>;
              #size-cells = <0>;
              port@0 {
                  reg = <0>;
                  #size-cells = <0>;
                  mipi_in_ucam3: endpoint@1 {
                      reg = <1>;
                      remote-endpoint = <&cam3_mvcam_out>;
                      data-lanes = <1 2>;
              port@1 {
                  reg = <1>;
                  #size-cells = <0>;
                  mipi2_csi2_mipicsi0_out0: endpoint@0 {
                      reg = <0>;
      &mipi2_csi2 {
              status = "okay";
          ports {
              #size-cells = <0>;
              port@0 {
                  reg = <0>;
                  #size-cells = <0>;
                      reg = <1>;
                      remote-endpoint = <&mipi2_csi2_mipicsi0_out0>;
              port@1 {
                  reg = <1>;
                  #size-cells = <0>;
                      reg = <0>;
                      remote-endpoint = <&cif_mipi_lvds2>;
      &rkcif_mipi_lvds2 {
          status = "okay";
          port {
              cif_mipi_lvds2: endpoint {
      &rkcif_mipi_lvds2_sditf {
          status = "disabled";
        lin @veye_xumm
        @veye_xumm请问,你们调试的时候有遇到这种情况吗?没有数据流输出,一直阻塞 16a1f873-dc28-49a3-9b52-47e9ce0a76fb-image.png
          veye_xumm @lin
          @lin 你是否用的是外触发模式?
          查看一下dmesg是否有报错?
          确认一下dts中关于mipi接口配置是否正确。
            lin @veye_xumm
            内核打印信息:1.txt
            还有您说的mipi接口配置是指链路设置还是mipi_csi2节点设置?
              veye_xumm @lin
              整个数据通路都得配置好才行。
                lin @veye_xumm
                  veye_xumm @lin
                  看你的拓扑图:
                  - entity 48: m00_b_mvcam 7-003b (1 pad, 1 link)
                          pad0: Source
                                  [fmt:Y8_1X8/1920x1200@100/6000 field:none]
                                  -> "rockchip-csi2-dphy1":0 [ENABLED]
                  你这边设定i2c-7接口配套的mipi硬件接口是:csi2-dphy1
                  真的是这样的吗?
                  我给你的我们调过的那个dts,用的可是csi2-dphy0啊!
                    lin @veye_xumm
                    @veye_xumm said in 相机采集图像阻塞:
                    i2c-7接口配套的mipi硬件接口
                      veye_xumm @lin
                      @lin 你是用的OK3588-C这个开发板吗?
                        lin @veye_xumm
                        @veye_xumm 是的
                          lin @lin
                            veye_xumm @lin
                            没有要求,相机自己有时钟。
                            你直接用这个dts,然后配合我们官方发布的驱动。
                            应该可以直接调通i2c-7这一路才对。
                              lin @veye_xumm
                                veye_xumm @lin
                                你用的相机型号是什么? 用哪个命令做的取图?
                                  lin @veye_xumm
                                    veye_xumm @lin
                                    应该跟这个没关系。
                                    你这个命令也没有问题。
                                      lin @veye_xumm
                                      自己画的转接板
                                        veye_xumm @lin
                                          lin @veye_xumm
                                          功率不够需要怎么解决,外加电源吗?功率需达到多少可以呢?
                                            veye_xumm @lin
                                            功耗是657mW
                                            你这个是带负载测量的吗?使能取图之后再测。
